Can't bury it
Old 04-21-18, 12:20 PM
maarkr's Avatar
Received 4 Votes on 2 Posts
Question Can't bury it
I want to run a line/conduit from an exterior GFCI outlet box to a shed about 6' from the home. I just need a std 15 amp outlet in the shed and a light. my prob is the line can't be buried... 6" down is ledge.
Now what?
Old 04-21-18, 01:04 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You could go overhead. .
Old 04-21-18, 01:51 PM
Received 23 Votes on 19 Posts
Bury at the 6 inches and cover with 2 inches of concrete and place marker tape on top of concrete and backfill.
Old 04-21-18, 02:35 PM
pcboss's Avatar
Received 30 Votes on 26 Posts
Would using an extension cord br that hard to do? How often is the shed used?
Old 04-21-18, 02:48 PM
ray2047's Avatar
NEC table 3005 column 2. If you use RMC you can go 6" no concrete.
Old 04-21-18, 08:02 PM
Received 28 Votes on 24 Posts
#1, No way would I just plug it into an outlet on the side of the house!
Should be on it's own circuit back to the panel
Out building should be 20 amp. not 15.
Outlets in out building need to be GFI protected.
Run the wires in conduit.
Pattenp suggestion would also be legal.
Old 04-22-18, 08:25 AM
pcboss's Avatar
For occasional usage a cord would be fine. The OP already has gfi protection at the exterior receptacle . A 15 amp circuit will power many small power tools. It would not need to be 20 amps.
