Insulate igniter wire against heat
Old 04-22-18, 09:53 PM
Question Insulate igniter wire against heat
Hello,
I hope this is proper section to post, if not please move.
I've tried searching here and amazon.com for a simple and cheap solution to insulate wires that go from igniter on my propane grill. Any idea what I can get to wrap the wire so if it ever too much heat get on it they don't catch on fire?
Igniter has 1.5V battery so no high voltage and I need less than 10FT of insulation.
Thanks!
Old 04-22-18, 10:08 PM
pcboss's Avatar
Received 42 Votes on 37 Posts
The wires temperature should have already been considered when the grill was designed . I don't think you need to do anything . I never had an issue with my grill.
Old 04-23-18, 05:25 AM
T
Received 15 Votes on 15 Posts
Is this something you made? In any case, shop for fiberglass flexible tubing.
http://www.mouser.com/catalog/645/usd/1255.pdf
ANd, there is very high voltages during the strike at the igniter. Greater than 10kV, I believe.
Old 04-24-18, 09:54 PM
Question
Thanks guys for the replies!
Wires were already replaced by the manufacturer due to being very close to the source of the heat and I'm trying to prevent it happening in the future.
No, I have not made the grill I've looked at that link and its way too much (100 FT). Looking at the temperature specs this seems way better
Melt Temp: 2,048F/1,120C
Operating Temps: -94F to 1,202F (-70C to 650C)
https://www.ebay.com/itm/TechFlex-FG...-/232677412477
Old 04-25-18, 04:02 AM
Norm201's Avatar
Received 135 Votes on 123 Posts
At our store we assemble all grills, including Grill Pro, Webers, Thermos, Broil Mate and there is no special wrap for the igniters. As long as the wires are not within 1/2 inch of the box or heat source.
Old 04-25-18, 02:54 PM
They are about 1 inch from the cook box.
Attached is the picture of wires on fire. Hard to believe but it can happen and I'm trying to prevent it form happening in the future. Dealing with the manufacturer to get the replacement was a nightmare.
