Adding an Electrical outlet
Old 04-26-18, 06:21 PM
P
i would like to add an electrical outlet to my kitchen island. The island sits on a concrete slab so I canít come up from the floor with a new circuit. The cook top is electric and is wired with 4 wires, can I use these wires to add a 15 amp 120 circuit?
Old 04-26-18, 06:31 PM
pcboss's Avatar
Received 103 Votes on 89 Posts
The cooktop wiring is not the proper ampacity to allow the installation of a 20 amp receptacle.
Old 04-26-18, 06:36 PM
A
How were the original wires run? If there is existing conduit, you may be able to add to it
Old 04-26-18, 06:55 PM
Received 83 Votes on 78 Posts
#1 You need 20 amp. GFI protected, not 15 amp. in a kitchen.
#2 That cooktop uses 240 volt, not 120, so no that will not work.
Old 04-27-18, 11:39 AM
Z
Received 157 Votes on 139 Posts
I think Austin's comment is probably your best answer. Chances are, a conduit was run before the slab was poured, then the wires pulled through afterwards. If this is the case, and depending on the size of the conduit, another 2 wires could likely be pulled through for what you want.
