Looking to change this A/C disconnect box.
Old 04-27-18, 08:55 AM
Good morning. I am looking to change this A/C disconnect box has the plug that I turn over to turn this on and off has become difficult to insert. Would someone mind pointing me in the right direction as to what replacement I need to purchase. Yes, I will be killing the power to this before replacing. Thanks!
Old 04-27-18, 09:16 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Cheapest bet is a 60 amp A/C non fused disconnect at a big box store, usually less than 15.00. Or look online.
Old 04-27-18, 09:40 AM
Thanks for the reply. If you wouldn't mind confirming: https://www.homedepot.com/p/GE-60-Am...0RCP/100674085
Also, Can I assume that it is fairly easy to change?
Thanks!
Old 04-27-18, 10:43 AM
Received 510 Votes on 480 Posts
The function is interchangeable. In other words you can use any disconnect but make sure the wires will reach to the new terminals.
The one you linked to is fine.
Old 04-27-18, 12:32 PM
Thanks guys. Wound up getting this one, https://www.homedepot.com/p/Halex-60...F60R/205785642
They didn't have the GE one in stock...
Old 04-27-18, 01:08 PM
That should do the job.
