2 120 v wires to 240 v wall heater
Old 04-28-18, 04:41 PM
F
I am replacing 2 baseboard heaters, the first was supplied by two 120 v 12/2 wires from a 20 Amp double breaker, the second, one 12/2 wire from the first heater. can I use the same 2 wires to supply one 240 V 3000 Amp wall heater?
Old 04-28-18, 05:26 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No, but a common misconception. It was supplied by both legs of the 240 volts supplied to your house.
That would be 3000 watts not amps. Yes, if only one heater.
Old 04-28-18, 06:00 PM
F
Thanks, any idea why they would only run one 120 to the next heater it was the same length baseboard ? yes I meant to say watts
Old 04-28-18, 06:04 PM
Received 1,525 Votes on 1,408 Posts
Usually 120vac heaters are shorter and much lower wattage.
A 120vac heater would have to be under 2000w on a 120v circuit.
From your description of wiring.... both heaters are 240vac.
Old 04-28-18, 08:31 PM
pcboss's Avatar
Received 114 Votes on 99 Posts
I suspect you mean there were two cables in the one heater but only one in the second heater . That would be the end of the run. The first heater had power in and power out to the second baseboard .
