Add additional bus bar to old GE panel
Received 0 Votes
Add additional ground/neutral bar to old GE panel
My house was built in 1972 and has the original GE panel in it. I'm currently replacing the electric water heater with a gas tankless, and so the dual pole 30A circuit needs to go to a single 20A. My issue is that my ground and neutral bars are full. It looks like there is space to add one, and they still make the model the panel has listed on the door, but i'm not finding one that would install elevated over the other 2. My other option would be to double up some of the grounds. Should i go that route? Or does anyone know where i might find the right part? Thanks!
Attachment 93009Attachment 93010
Hi, if you have room on the side of the panel maybe you could install a ground bar like this.
https://www.homedepot.com/p/Square-D...TACP/202353315
Geo
Geo
