Reload this Page >
Installed new fixture and now several lights on same breaker are out
Old 05-04-18, 06:29 AM
T
Hi all! I am hoping to get some help on a new light fixture I tried to install. We have an old fixture we wanted to swap out an a old fixture to match the newer fixtures in the same area. Ok, no problem. I've changed out fixtures before should be easy. Well I get the old one off and I note two additional 2-conductor cables in the box besides the one in use. No problem, probably just something I've not run into before so I leave them be. I connect the new fixture to the box (white-white, black-black, ground-ground. Restore restore power and not only does the fixture installed not work but neither do for other lights on the same breaker. However another light and Outlet on the same breaker do still work. The light I tried to change is controlled by a single switch. The other for light fixtures that are now out, are also controlled by single switches.
not sure where I went wrong on installing this fixture. I checked the wires in the box with my non-contact tester. The two black wires wired together appear to be hot, the two white wires wire together appeared to be not hot. The the white and black wire use for the fixture do not read as hot. The attached picture is what I have in my box at this time. Any help you can provide is greatly appreciated. Thanks in advance!
Old 05-04-18, 07:38 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Non contact testers show false positives way to often to be useful for real testing. Test the disconnected cables with a multimeter or test light. Is one cable hot tested black to white with switch off?
If there is only two wires at the switch though, just a black and white on the switch, you have a switch loop. Have you worked with switch loops?
Switch loop example:
Old 05-04-18, 11:00 AM
T
Thank you for the reply. I will check with a multimeter after work. I have not worked with switch loops in the past. I will check the switch as well and see if I have a switch loop.
Old 05-04-18, 12:35 PM
pcboss's Avatar
Received 111 Votes on 97 Posts
If the only connections you changed were the ones going to the fixture it should not changed anything .
