Change rotation of a 12V motor back and forth
Old 05-07-18, 06:19 PM
I have a 12V electric motor from a treadmill that I want to be able to change back and forth from cw to ccw. Any suggestions on switches and wiring would be appreciated.
Old 05-07-18, 06:32 PM
Received 1,531 Votes on 1,414 Posts
Welcome to the forums.
Depending on the load.... it can definitely be done with relays.
Possibly a switch.
Is there an amperage draw for that motor ?
If the load was under 15A or so.... you could use a HD toggle switch....
Old 05-07-18, 06:40 PM
L
Received 105 Votes on 91 Posts
It can be done with DPDT switches with center off. Just wire center terminals to the motor and one side of terminals to 12V + and -. The other terminals with opposing polarities.
You can make one with a 4 way switch as well, but then you will need another switch for on/off.
Make sure the motor comes to complete stop before switching the direction. Otherwise it will fry the motor or the wiring.
Old 05-14-18, 04:35 PM
Thanks for the advice. I picked up a Grote 15A 3 position switch at a local auto parts store. When I got home and opened the package it says "15A 125VAC / 10A 250VAC/ On Off On" but nothing about 12 V application. Does it matter if I use this switch in a 12V application. I live 40 Km from town so I'm not real anxious to go back if it isn't necessary.
Old 05-14-18, 04:48 PM
The voltage rating of a switch is the maximum voltage it can be used on.
That should be fine..... give it a try.
