GFCI Tester - Dim Orange Light - Reversed Hot/Neutral When Button Pressed
Hello all,
I was checking all my electrical outlets with a GFCI tester. All outlets show correctly wired. Came across one outlet (non-GFCI) where the right orange light is dim. Googled and found that it may be poor ground.
Strange thing is when I press the button on the GFCI tester, red light and middle orange light come on indicating reversed hot/neutral. All other non-GFCI outlets don’t give this result when I press the button. All other outlets have two orange lights remain lit.
Any thoughts what might be going on with this outlet?
This only makes sense if the middle orange is also ON before you press the button.
In that case what Tolyn said is right. When you press the button, a small current is passed from hot to ground to trip a GFCI, but if your ground is not grounded, it would float and carry a voltage/current sufficient to turn on the red light that sits between ground and neutral.
That's a good trick question. I have to draw a diagram to figure this out.
Thanks for the responses. I opened up the boxes as well as follow wires in the attic. Found the culprit in a junction box inside the attic— ground wire was loose. Reattached the ground wire and problem solved.
