turning 450 Watts to 2000 Watts
Old 05-14-18, 12:11 PM
R
Please see attachment.
Working on a new project to power my server which now consumes about 2000 watts. I'm trying lower it to 450Watts by using a electric motor powered from a wall outlet that will turn a car alternator that will charge a 12v DC battery which will be connected to a 2000 Watts inverter where my server will be connected too?
I have no problem running the alternator 24/7 as long as its using 450-500watts for the electric motor- my goal is to save 1500watts - What you guys think?
Old 05-14-18, 12:26 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You would be drawing 167 amps from the battery. It won't last that long at that amp draw. Average alternator puts out 100 amps, 67 amps less than you need to charge the battery.
Basically you would be trying to pour 5 gallons of water from a one gallon bucket. If 500 watts in then max out is 500 watts (minus loses due to mechanical and electrical resistance).
Old 05-14-18, 12:49 PM
R
Thanks for the reply, so even if I got a 167 amps alternator, a max 1000 watts motors, and add a large pulley, the output will still be less then 1000?
Old 05-14-18, 12:53 PM
P
Received 752 Votes on 691 Posts
This is the third thread you have started asking an impossible or extremely impractical question about electricity. I suggest that you do some basic reading/study about electricity.
Old 05-14-18, 01:02 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
There's NSTAAFL...........................
Old 05-14-18, 02:13 PM
R
its not free lunch, trying to lower the cost of electricity...
Old 05-14-18, 02:33 PM
Gunguy45's Avatar
Super Moderator
Trying to get more output power than there is input power is asking for a free lunch. Basic conservation of energy law.
Since there are losses in any conversion, you actually have to put more power in than you can possibly get out. That's not even including the cost of the devices needed to convert from one form to another.
No matter what faked You Tube video's may appear to demonstrate.
Old 05-14-18, 03:06 PM
H
Received 137 Votes on 119 Posts
Just buy the 2000W bladeserver power supply
https://www.amazon.com/IBM-74P4452-W.../dp/B016YK1364
Old 05-14-18, 06:18 PM
Received 1,344 Votes on 1,242 Posts
That's a joke.... right Hal.
Old 05-14-18, 07:59 PM
Tolyn Ironhand's Avatar
Received 253 Votes on 221 Posts
If you really want to lower the cost the electricity you have to make an up front investment. Install a wind turbine or solar array. It will cost you thousands of dollars but should pay for itself in 15 - 20 years.
Old 05-14-18, 08:35 PM
H
Not supposed to be.
If the OP has a server that needs about 2000 watts,
the OP needs to buy a high efficency power supply that puts out about 2000 watts.
https://images-na.ssl-images-amazon....L._SL1500_.jpg
Old 05-14-18, 08:49 PM
The server is drawing 2000 watts right now from the A/C line.
A different power supply won't change that. A high efficiency unit may save a few watts of power
but not really enough to make the investment worthwhile.
