Extending outside outlet
I have a GFCI outlet in crawlspace and would like to extend it outside for easier access. Would it be acceptable / safe to run new wire from the existing outlet by just plugging into that outlet then running the other end of the new wire to a new GFCI outlet placed in the desired location?
No not acceptable. Connect UF-b cable to the line side of the existing receptacle and place a weatherproof GFCI receptacle in a weatherproof box with an in use cover outside.
(You could use a non GFCI receptacle outside if you come off the load side of the existing GFCI but it would be less convenient if there was a trip.)
