Quick lower level question
What does the 12 Volt 180 Watt on my cigarette lighter receptacle mean exactly?
Hi, that is the capacity of that outlet, any device you plug into it should not be rated more than 180 Watts.
Geo
Geo
It can deliver 15 amps max. That's quite a bit for a 12V device. Small converters for phones and such will draw a small fraction of that. Larger things like tire inflators will easily draw 10+ amps when starting and would blow the fuse in older cars that only had 8 amp (96 watt) rated lighter sockets..
That receptacle should be used to power devices that draw no more than 15 amps. A heavier current draw if permitted by a higher amp rated fuse or breaker for the circuit will shorten the life of the receptacle noticeably and could produce a fire hazard due to overheated contacts.
Installing this receptacle on a lower amperage circuit e.g. 8 amps is workable but limits flexibility and versatility. The fuse will limit what equipment can be plugged in and used.
I am not sure whether, in automotive circuits, it is permissible to install multiple receptacles on a single circuit with combined amperage sufficient to max out all of the receptacles e.g. two 15 amp (180 watt) receptacles on one circuit with a 30 amp fuse. That is generally not permitted in household circuits.
