Junction box for backyard.
[SIZE=3]When we moved into our house there was a yard light installed at ground level that covered a good portion of the backyard. Unfortunately, one too many games of soccer eventually took it out. When I bought a new light to install I began to worry that the junction box is not correct and is potentially dangerous. [/SIZE] The box (whish is 95% buried in the ground) looks to be a plain metal wall box with a metal plate over the front. The light was then screwed into the conduit hole on the top. It certainly isn't waterproof.
What type of box should I replace it with, and should it be above ground? Thanks in advance for you thoughts.
Welcome to the forums.
A metal junction box is not normally heavy enough to hold up any light fixture. It would just fall over unless something was down in the ground. Possibly it's a junction box on top of buried conduit ?
Can you post a picture of it.... How-to-insert-pictures
5 out could look at some of these depending on the fixture type.
http://www.aifittings.com/catalog/gard-n-post/
