Slide switch problem
Old 05-28-18, 04:11 PM
XSleeper's Avatar
Received 997 Votes on 908 Posts
So at our congregation we have a Rainbird ESP 8si controller located in the basement. Looks similar to this: https://d3nevzfk7ii3be.cloudfront.ne...GNPE6.standard
The slide switch in the lower right is acting goofy. It's called the schedule control switch. I believe it's just a 4 position slide switch that slides left and right.
Basically it's not wanting to make contact when it is to the far right position. If you fiddle with it a lot it will finally make contact as long as you don't breathe on it or touch it.
Do you think a little electronic contact spray in the switch would do any good? I will unplug it and blow it out with air before plugging it back in.
Old 05-28-18, 04:29 PM
Received 1,613 Votes on 1,485 Posts
Those slide switches are crap and corrode easily once the grease in them is gone.
They corrode even faster in a damp place like a basement.
Yes.... contact cleaner will clean it but it will become hard to slide.
Old 05-28-18, 05:51 PM
XSleeper's Avatar
Well, it didn't help. I will just have to get used to using the fixed programming (left half of that switch) I guess.
