How to modify breaker for 5hp 3-phase motor Sawstop?
Old 05-30-18, 11:51 AM
I'm thinking about purchasing a 5hp 3-phase motor Sawstop table saw. My current outlet is 220v 15amp. For it to work with 5hp 3-phase motor Sawstop, what do I need to change on my breaker panel and/or the receptacle?
Thanks!
Old 05-30-18, 05:25 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If this is residential you have single phase power and you can't change to 3-phase. (You can't change to what you don't have.) The saw can be run on a converter to 3 phase but that might cost as much or more then using the correct motor. Or is this a commercial shop with 3-phase power?
Old 05-30-18, 05:45 PM
Received 319 Votes on 293 Posts
Solid state phase converters are small and compact but there will be a power loss so your 5hp motor may only 4 hp and they don't like it when you turn the motor on and off frequently. There are also "mechanical" phase converters that are basically a single phase motor turning a three phase generator which can generate nice sine wave power so your motor runs at full power but the converters consumer energy and have a decent physical size. So, if only single phase is available I usually change the motor but if the machine has significant controls I'll leave it three phase and run a converter.
Old 05-31-18, 08:56 AM
Awesome! Thank you for the detailed response. I understand it now. And no, this is residential area not a commercial shop.
Old 05-31-18, 01:51 PM
Okay, so if I go with a Sawstop model that is 5hp single phase, something like this one, then I should be able to get my breaker panel to support it, correct?
Old 05-31-18, 06:49 PM
ray2047's Avatar
Yes, you should be okay. .
Old 06-01-18, 05:50 AM
Yes, amperage is easy to handle with the proper sized breaker and wire. Phases (single or three) are baked into the electricity supplied to your house or business and requires a phase converter to go from one to the other. If you can order the machine with a single phase motor go that route.
