GFCI Breaker or GFCI Outlets
Old 06-01-18, 11:27 AM
R
I'm having a detached shop built and will have a 200 amp panel. For the general use outlets is it better to use a GFCI breaker or put GFCI outlet in first position and feed other outlets. I know the breakers are more money.
Thanks
PS A scroll over view on the search results would be great.
Old 06-01-18, 03:32 PM
pcboss's Avatar
Received 181 Upvotes on 159 Posts
Both provide the same level of protection . Gfi receptacles can be easier to reset as they are normally closer to the point of use, however the breaker in the panel stops the need to find a gfi behind a box or pile of stuff. The receptacle is cheaper.
