Wiring a retail showcase
Old 06-01-18, 08:17 PM
I have a situation where I need help determining how to correctly setup electrical for these cabinets. Tbe ends look to be a Nema L6-30P. I need to wire these so i can connect the cabinets together and power the lights. All i have are 110 outlets where I will be placing these. Photos on this link: https://www.dropbox.com/sh/qrbtywa6ediyvar/AAD7h-06Wquc3jLN1l8M7Qxha?dl=0
Old 06-01-18, 09:15 PM
Received 508 Votes on 478 Posts
Those are some old fixtures with starters. Hopefully they still work.
Why don't you put standard 120v cords on the units. Get rid of the old twistloks.
Old 06-02-18, 09:52 AM
I was hoping to wire them all together but have the option to quick disconnect. I havent messed with this stuff in a long time.
Old 06-02-18, 10:24 AM
As they are 120v fixtures you don't need to do anything special.
You can still use twistlok caps if you want.
What specifically do you need help with ?
Old 06-02-18, 10:36 AM
Does electrical code say anything about using wire nuts to splice two cables together? Not for this application but I have a commercial cooler that someone cut the end and add it more cable but they just taped it together.
its a True cooler and the specs are... 115v 1/2 hp F.L. Amps 7.3 and PH 1. Since I don't want this orange extension cord cable spliced on the end I need to fix this.
Old 06-02-18, 11:14 AM
pcboss's Avatar
Received 39 Votes on 34 Posts
The splice should be in a junction box with a cover. Or replace the entire cord.
Old 06-03-18, 10:42 AM
So im going to cut those twist lock connectors off and replace with standard receptacle plugs. Id like to add a switch so i can turn the cabinets off and on as needed. Im not familiar on how to add a switch, ive replaced but never added one so i want to be sure ite done correctly. I wont really be ppwered anything with a load, just lights and misc items. A diagram on what to do or some instructions will be awesome.
Old 06-03-18, 12:45 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Hots in and out go to the switch. Neutrals are wired through bypassing the switch.
