Wiring Dimmer Without Screws
Old 06-02-18, 10:00 AM
Hi, I would like to install a dimmer in a box with 2 switches:
The dimmer is a Lutron Diva CL with wires instead of screws. The thing that is throwing me off is the black wire that is stripped in the middle and connected to both switches:
How would I deal with this? Thanks in advance.
Old 06-02-18, 10:05 AM
Received 381 Votes on 358 Posts
Move the loop to the switch that is remaining leaving you with a loose black end.
Otherwise cut the loop, make it a splice and add the dimmer wire.
Old 06-02-18, 10:28 AM
pcboss's Avatar
Received 32 Votes on 27 Posts
That is just providing power to both switches. You could cut it at the split and add two pigtails to feed each switch.
Old 06-18-18, 06:49 AM
Thanks for the quick reply. Sorry my update is not as quick.
I did as instructed and it worked great.
Thanks again.
Old 06-18-18, 07:01 PM
No problem. Thanks for letting us know how you made out.
