Any issues using a dedicated 15 amp circuit for a product that recommends 20 amp
Received 0 Votes
I had a dedicated line run to the breaker to run a heat pump, that is no longer in use that now that installed Central A/C. it's a dedicated 15 amp breaker, and I'm pretty sure it's on the smaller 14 AWG wire.
I was going to use this line to convert a soaker bathtub to a new whirlpool tub that recommends "20 amp GFCI" in the instruction manual.
Maybe not enough info to know for sure, but anyone see any critical issues with using a 15 amp circuit with a whirlpool tub that recommends 20 amps?
Thanks
Thanks
What is the nameplate amps of the tub? Typically when a manufacture recommends/requires a 20 amp circuit it is because it draws more then 12 amps, which is the max allowed continuous load on a 15 amp circuit.
Received 0 Votes
Thanks for the replies. Good feedback. I actually haven't had the tub delivered, which is why I was thinking I might be premature before actually getting the nameplate amps from the motor itself. I'll just wait until the tub arrives from the manufacturer in a couple weeks and reassess the actual nameplate amps at that point-in-time. I just had some time to burn in "prep time" before I actually started the project and everything was delivered, so I thought I'd inquire on the whole 20 amp question since I'd have to go create a brand new circuit if 15 amps won't work.
Thanks again.
Thanks again.
Received 0 Votes
OK. Got the tub. Name plate is:
Hmax: 12m
Qmax: 380
7 Amps
L: 306
L1: 139
Class: 155(F)
CAP: 25 F/300V
Not sure I know all of those components, but the key ones are there. Any thoughts on whether this could run easily on a 15A breaker?
Hmax: 12m
Qmax: 380
7 Amps
L: 306
L1: 139
Class: 155(F)
CAP: 25 F/300V
Hmax: 12m
Qmax: 380
7 Amps
L: 306
L1: 139
Class: 155(F)
CAP: 25 F/300V
Not much here I recognize. 7 Amps is about it. The Class 155 seems like an insulation spec you would find on a motor or transformer. The CAP is a rating on a starting capacitor? L, L1, Hmax, Qmax = ?????
Are you looking at a motor nameplate or the PRODUCT nameplate?
Qmax: 380
7 Amps
L: 306
L1: 139
Class: 155(F)
CAP: 25 F/300V
