No Power at Dryer Outlet
Old 06-12-18, 08:36 AM
We just moved into a new (to us) home where the previous owners had the laundry in a first-floor mudroom, but we are trying to put our new appliances in the basement where they originally were when the house was built.
The dryer receptacle in the basement does not have power. I assume they switched something when they moved the appliances upstairs so I'm trying to figure out how to get the power back to the basement dryer receptacle.
Old 06-12-18, 08:55 AM
Geochurchi's Avatar
Received 18 Votes on 18 Posts
Hi, is there a cable running to the basement location? is there a junction box near where the dryer cable goe# up stairs?
Geo
Old 06-12-18, 11:56 AM
Not sure - I can see what I find when I'm at home later.
Old 06-12-18, 01:58 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
One more assignment: Is there a disconnected 3-conductor cable (black, red, white) in the breaker box.
Old 06-12-18, 02:00 PM
yes, ray - that i remember from being in the box in the past
edit: just a red and a gray
Old 06-12-18, 02:14 PM
Actually here is a picture I took during our walk-through when we first looked at the house.
Old 06-12-18, 07:30 PM
ray2047's Avatar
Open the dryer receptacle and see if the colors match.
Old 06-12-18, 07:46 PM
In the dryer receptacle is red, grey, white, and and just a loose copper ground
Old 06-12-18, 08:55 PM
ray2047's Avatar
Remove the current wires from the dryer breaker and connect the loose wires. Using an analog multimeter see if the receptacle is now hot. (They probably left ground and neutral connected.).
Old 06-13-18, 07:15 AM
I have no experience with this type of electrical work - I don't know that I want to be messing around in the panel box as a novice. But thanks for pointing me in the right direction - I think you're spot on with what needs to happen!
Old 06-17-18, 11:04 AM
So I realized the breaker process was pretty easy and got the dryer running! But...
Now I see that its venting directly into the utility room in the basement - I can't seem to follow any sort of path to outside, but im sure it had to be going there at some point.
Old 06-17-18, 11:22 AM
Received 379 Votes on 356 Posts
It didn't have to be. Many people don't see the need to vent outdoors. If you don't mind high amounts of moisture and dust in the air.... you can keep it inside. Gas must be vented outside..... electric does not.
Otherwise.... you will need to locate a path to the outside. If the dryer is in the center of the house.... it can be tough to find a clear path out.
