Outside outlet with plug cover.
Old 06-13-18, 05:16 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Am installing a outside outlet. Using pvc box. Should I seal up the lower hole or leave it open?
2. Have a speakers in carport where I work i have a radio hoked to them now. Would like to share them with a TV When either TV or radio is off. Would it hurt anything?
Old 06-13-18, 06:51 PM
P
Received 636 Votes on 588 Posts
Are you talking about 120 volt AC in the box or low voltage/speaker wires? In either case I would seal the hole but for different reasons. If the box contains 120 VAC it needs to be sealed for safety. You don't want anyone to be able to stick a finger in and touch a hot wire. If it's just low voltage or speaker wires I'd still want it sealed even if just with tape to keep insects from building a nest inside.
Old 06-14-18, 01:39 AM
pugsl's Avatar
Sorry for confusion @ different projects. 120 to outlet and will seal hole. Speakers a different job.
