Sub panel
Old 06-21-18, 05:13 AM
H
Sub panel
i have a workshop I ran two number ten wires too. And hooked them to a sub panel as one wire. Can I successfully pull 220 from this sub panel to run a pool heat pump. I am thinking I should replace the two 10 gauge wire for one six gauge. But I don't know what kind of wire I need. I know it's a #6. I need it t be in ground cable. Is the wire to be 6/2 or 6/3? Thanks
Old 06-21-18, 05:53 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
You need four wires for a subpanel, hot, hot, neutral, ground. Only very large wires can be "twined". #10 can't be.
You can either use 6-3 UF-b cable direct buried or conduit with four THWN individual wires, one #6 white, two #6 black, one #10 green. If you use continuous conduit best to use individual wires because UF-b is hard to pull.
Old 06-21-18, 05:00 PM
H
Which type would you suggest direct burial or conduit? Plastic conduit? Is one better? Is one cheaper. My run is near 60 feet counting length of both feed wires up the walls. After upgrading with the six wire will I be able to pull 220 from the sub panel? Thanks for your help, btw
Old 06-21-18, 06:44 PM
ray2047's Avatar
No, your house has 240 volts. It is four wires not six..
PVC conduit or UF-b would be about the same.UF-b would need to be sleeved with conduit where it enters and leaves the ground. Conduit is buried 18" minimum, cable is 24".
Old 06-22-18, 08:06 PM
H
Thanks for your help ray when I said six wire I meant the size of wire
Old 06-24-18, 10:37 AM
H
THWN #6 wire individual. I looked this wire up to buy and the wire I found was not a solid wire but multiple wires. I thought this service wire would need to be a solid wire like number 10 wire for instance. So is this multiple wire the type I can use, for shop sub panel?
Old 06-24-18, 11:14 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
Larger conductors are stranded .
Old 06-25-18, 07:19 PM
H
I have seen # 6 wire with solid copper wire, just thought solid wire was better than stranded but guess not.
Old 06-26-18, 12:42 PM
H
THWN, when I search it they keep showing thhn-2, Saying but not really saying they use this now instead of THWN. I found the wire, on a web site, 90 dollars of wire and they want 30 dollars to ship. Any place you can recommend to purchase the single strand wire?
Old 06-26-18, 05:07 PM
P
Received 154 Votes on 126 Posts
When you say single strand do you mean solid copper? You may be hard pressed to find solid #6 THHN, not sure it's available. Just in case you don't know you can't buy just one length of one color and use it for the 4 conductors. The neutral must be white and the ground green or bare.
Old 06-26-18, 05:30 PM
pcboss's Avatar
Try a local electrical supply house.
solid is harder to work with than stranded.
Old 06-26-18, 06:59 PM
Tolyn Ironhand's Avatar
Received 365 Votes on 316 Posts
The only time I have seen/used solid copper #6 or #8 is bare copper for a grounding electrode conductor.
Old 06-27-18, 07:05 AM
I
Received 44 Votes on 42 Posts
THHN / THWN-2 is OK to use; it's the same wire. Most wires carry multiple ratings. Home Depot, Lowe's and Menards all sell #6 by the foot or by the spool, as will any electrical supply house.
