Can I run cable through the panel?
Old 06-28-18, 10:05 AM
Davejb's Avatar
Continuing my generator transfer switch install in my 2004 doublewide. Just got a good deal on a Reliance 10 switch unit @ my local electrical supply house. There is a plastic conduit that runs from under the home right into the bottom of the panel that contains the central air compressor wiring.
There's plenty of room to slide a 10/3 up from the bottom into the panel, then route it out the top of the panel to the transfer switch (other end connected to the genny plug outdoors). Is this allowed, just running a cable through the panel that isn't connected to anything in the panel?
Old 06-28-18, 11:02 AM
P
Received 45 Votes on 38 Posts
Yes it's allowed as long as you don't exceed the fill limits of the panel and or the conduit. Having what you think is plenty of space may not be enough by code.
Old 06-28-18, 11:26 AM
Davejb's Avatar
Thank you, I'll look into how to calculate that.
