new outdoor outlet
new outdoor outlet
I would like to add a new outdoor outlet. I was thinking about using an existing outlet that is on the inside wall, drill from bottom of that box through exterior of house then add a metal box. Does this seem feasible or would I need to run a new line to it instead from the panel?
The outdoor box I am thinking of using.
Metal box from lowes
Assuming the room is not a kitchen, bathroom, or dining room that should be okay. I would go through the back of the box. You will need a weather resistant GFCI receptacle outside.
it is my dining room's electrical box I would be tapping into. Why would that be a cause for concern?
The kitchen/dining receptacle circuit cannot serve receptacles outside those areas. You need another source of power.
