Service conduit gasket loose
The gasket where the service conduit meets the roof had popped out on one side again. It seems to happen with the change of seasons.
is there any particular outdoor adhesive I could use that would keep it in place?
Is this the correct orientation of your picture?
The metal part is the conduit on roof. Gutter blocks the view on the overhang where it comes down.
The black is the gasket.
Here's a zoomed out view
That's the phone line, which we don't actually need anymore but it's left in case.
I can't disconnect everything without an electrician so will have to go with the adhesive for now...
Push it into place and then silicone over the top?
The phone cable doesn't go thru the gasket.
That looks like quite a long piece of unsupported mast.
What's the distance between the mast and the pole ?
