Lights, outlets go out, but circuit breaker doesn't trip ???
this is from an old thread
but
living room dining room, kitchen
a total of 5 outlets, 2 light fixtures
go out
but the circuit breaker doesn't trip
any ideas?
none are gfci
txs
frankie #18
from an old thread
06-19-07, 03:47 PM
joed
Thanks for letting us know the cure. 90% of the time your problem would have been the GFCI
but
go out
any ideas?
none are gfci
txs
frankie #18
from an old thread
joed
Welcome to the forums.
Probably one of the most common problems we see here. Only a short will trip the circuit breaker. You don't have a short.... you have an open. You could have an open hot wire or an open neutral wire. You'd need a voltmeter to confirm that.
The most typical problem is that the devices are connected by using the push-in (back stab) connections. These connections loosen with age and are notorious for causing intermittent problems. You'd need to turn the circuit off and pull each device out of the box to check for a loose connection. If you find wires pushed into the back of the devices.... moving them to the screw terminals should fix the problem.
hi, guys
just got out of SIUH< tuesday
now, i should get a voltmeter
would a ampmeter give better results?
wikipedia has
voltmeter, multimeter, ampmeter
which is the best?
now, if you can help
i am a retired bell system tech
so i've been around
circuit breakers, lighting fixtures, etc
so
circuit breaker box is in hall
behind kitchen wall
one bedroom condo
kitchen light switch does not work
disconnected light fixture
2 countertop kitchen outs work
stove outlet don't work
refrigerator outlet has its own circuit breaker
stove outlet does't work
2nd kitchen switch power dining room ceiling fan
but dining room outlet works
3 living room outlets do not work
1 is behind other kitchen wall
porch light switch in living room don't work
powers porch light
should i change circuit breaker?
wouldn't the problem be in kichen
circuit breaker behind wall?
just so you know
idid call an electrician
who advertise "free estimate"
"no estimate
"i need to find the problem"
very vague, etc
means big bill
lol
thanks again
frankie
ps
what is a "spoiler"
how do i include or attach picture from "my pictures?"picture
if you want a laugh
go to "images"
https://www.google.com/search?q=funn...UDSth84J3HevM:
wikipedia has
which is the best?
so i've been around
so
behind kitchen wall
one bedroom condo
powers porch light
just so you know
"no estimate
very vague, etc
means big bill
lol
thanks again
frankie
ps
what is a "spoiler"
if you want a laugh
go to "images"
now, i should get a voltmeter would a ampmeter give better results? wikipedia has voltmeter, multimeter, ampmeter which is the best?
You will need to start removing receptacles and switches (without disconnecting the wires) that are not working and look for poor connections. The issue will be either the last working device or the first non-working device.
You should try also to reset all the circuit breakers. Sometimes it is hard to see a tripped breaker. Turn them all the way off and then back on.
one more thing
no way
it's the circuit breaker
no way
You're a retired Bell System tech with no meters ?
hi, guys
thanks to all
i'm asking
do i change the circuit breaker
i know circuit breakers
they are all on
one underneath the other
i have some headserts
i'm a tool afficinado
i got the old whiffy
prober
sounder tracer thing
and of course
dykes
and longnose pliers
i had a meter in special service to parralel the line
sorry, no electrical meters
tx's
frankie
thanks to all
i'm asking
they are all on
prober
and of course
dykes
and longnose pliers
tx's
frankie
When I was in high school (1976) I joined an Explorers Club at Bell Labs in Murray Hill, NJ. Not only did these guys have impressive arrays of equipment.... they had well equipped travel bags !
Anyway..... you should invest in a basic meter. An analog one from the home improvement stores is sufficient. A voltmeter tells you what you need to know. You check every breaker for output first and then go from there.
hi
thanks
you know, i was a nytel tech
but
bell labswwas no joke
they inventede the traqnsistor
that has gone frrom your
"traqnswistor" radio
cousin brucie
to the moon
pluto aND basically
out of this gaqlaqxy
i'm going to get the voltmeter
thanks
frankie
thanks
but
cousin brucie
to the moon
pluto aND basically
thanks
frankie
voltmeter????????????????????
Last edited by PJmax; 08-25-18 at 02:23 PM. Reason: removed personal info and added meter picture
You'll be using the probes in the left two ports on the meter. You'll probably never need to use the 10A max port. You'll be setting the meter to 200vAC
If you are comfortable inside the panel...... put the black probe anywhere on the metal panel box where you see bare metal. Touch the red probe to each single breaker one at a time. Each single breaker should show 120vAC.
hi
thanks so much for the rsvp
i have taken out 3 outlets
and
2 switches
they are all hardwired
closest to circuit breaker box
now
power.......red
ground........black
i haven't opened breaker box
but
no power
intermittent power
it's got to be the breaker
last question
if i go to ground with black probe
(gem box)
and
touch red lead
to
outlet (that is not working) screw
what should my reading be?
thank you
frankie
and
2 switches
now
power.......red
ground........black
but
no power
intermittent power
last question
(gem box)
and
touch red lead
to
thank you
frankie
hi
i don't believe it either
but
to test an outlet
Vm setting is
600
200
20
2
now
i have a working outlet with no plate
i put black probe to gem box, ground
red probe to one side of bs cable
the readings fluctuate
1661
-19
-002
a dozen of them
isn't 120v a universal power dispatch
at least in US
why no 120v sertting?
event hen
why no 120v
(119, 112, 126, etc
reading?
not for nothing
"to brass....."??????????????????????????
txs
frankie
but
to test an outlet
Vm setting is
600
200
20
2
now
1661
-19
-002
a dozen of them
at least in US
event hen
why no 120v
(119, 112, 126, etc
reading?
not for nothing
txs
frankie
On YOUR meter..... it has a 200v and 600v setting for AC voltage. You will using the 200vAC setting for your testing. The 200v setting means...... measuring all AC voltages under 200v.
It is very hard to follow what you are doing.
You asked to test breakers. I gave you instructions for that.
If you want to test at receptacles...... measure between the small slot and the ground pin of the box. The small slot is the BRASS screw that Ray mentioned. There should be 120v from the small slot to ground.,
There is a book available at many home improvement stores and on book clubs called "Wiring Simplified". You need to invest in and read that book to become more familiar with general wiring.
hi
tx's
it's a bummer
but
i'm beset by medical,, yada yada things
very distracting
i know
i have to do this as a order
"fix outlet"
"check circuit breaker"
but
enery is low
u r de best
frankie
tx's
it's a bummer
but
very distracting
i know
"fix outlet"
but
enery is low
u r de best
frankie
