how to add outdoor outlets by the patio
I am looking to add outlets by our patio to plug in pumps for an intex above ground pool. there are two devices
intex pump 637R ac 110/120 V 1.4amp, 99 watt
intex saltwater system eco5510 110/120 V 0.6amp, 65 watt.
I have outside outlets on the house on a 15 amp breaker.
Can I tap into the existing outlet and run wire about 50 feet underground? what wire and do I need to use pvc or other housing?
(I am assuming that running extension cords to these two devices would not be the best choice but it would certainly be simpler and cheaper if it is safe.
these devices both have very large gfci plugs on them so I would need two separate outlets and a waterproof box big enough to handle these monstrous plugs.
any suggestions would be appreciated.
thank you
thank you
If you do use cable, you will still need to protect it as it comes up from the 12" or 24" in the ground.
UF cable cannot be used for pools. The ground has to be insulated . What room are you thinking about extending from?
thanks for the responses.
pcboss, I want to come out of an outlet on the outside of the house.
Do you have any suggestions for a waterproof box for the outlets that would be large enough for the two overlarge gfci plugs?
thanks
thanks
You'll have to use two single gang boxes set a few inches apart with a conduit nipple between them. I've never seen an oversized two gang exterior box or cover.
