Remote Start
Old 07-13-18, 07:23 AM
B
Remote Start
I purchased an RF remote starter rated at 3hp and 15 amps for my Powermatic 3hp 220v dust collector which pulls 15 amps. The DC originally had an IR remote starter which required line of sight which I bypassed by connecting a 220v pigtail to the leads coming out of the motor and plugging that into the new RF remote starter.
it works but every time I start after some time has passed the remote controller kicks out and I have to press the reset button, after which the remote works every time unless it has been off for maybe 5 minutes.
can anyone tell me what I can do to alleviate this problem? Thanks.
Old 07-13-18, 11:12 AM
I
Sounds like it's overheating. You may need a higher rated unit or run it though a contactor rated for at least 3HP.
Old 07-14-18, 12:15 AM
Received 3,194 Likes on 2,869 Posts
The remote controller has a reset button on it ? Pretty strange.
Or the motor has a reset button on it.
More information would be needed on the remote control.
Old 07-14-18, 03:52 AM
B
The controller itself has a reset button at top rear center. This
https://www.amazon.com/Collector-Rem.../dp/B071R7G55G
is the same unit, although I bought mine from Peachtree USA.
Old 07-14-18, 07:10 AM
P
Your dust collector is exceeding the amp rating of the RF switch and tripping it's internal breaker. You'll need to use a clamp-on amp meter to see the actual running amps of your DC. It could be a faulty RF switch. What size wire and length did you use for the pigtail to plug into the RF switch? Are you using the RF switch on an extension cord?
Old 07-14-18, 08:08 AM
B
I used 12/3 which I spliced to the motor leads making the length from the motor to the RF controller about six feet. The RF controller has a five and a half foot cord which plugs into a 220v dedicated receptacle on its own circuit.
Old 07-14-18, 10:35 AM
Unfortunately your dust collector is running too near the switches safety rating. I have built a couple for customers using a basic remote and small contactor.
There is a heavier version available for increased cost.
Woodworking-Products-LR220-3-Collector/remote switch
Old 07-15-18, 07:08 AM
B
I am going to cut down the length of the pigtailby maybe three feet and double check my splices and see if any of that makes a difference.
when I purchase an item with a rating ai expect the item to function within that rating.
thanks for all responses.
Old 07-15-18, 10:14 AM
You would new an ammeter (amprobe) to determine if your motor is drawing very near or over 15A of power.
