Wiring a GE combination wall oven/microwave
Old 07-19-18, 10:10 AM
P
Hey guys, I just installed this unit in my kitchen remodel and wanted to double check my thoughts regarding wire and breaker size. Based on the product description, I believe I need a 40 amp dbl pole breaker and 8/3 wire. The unit is (at most) 65 feet from the panel. Is the equipment I listed above sufficient and does 8/3 need to be run inside conduit?
Thanks very much in advance.
Peter
Old 07-19-18, 03:07 PM
pcboss's Avatar
Received 48 Votes on 42 Posts
The unit needs a 40 amp 120/240 volt.circuit feed by #8 .
If the cable is subject to damage it would need protection.
Old 07-19-18, 05:50 PM
P
Excellent. Thank you pcboss.
Have a great evening
