Recommendation right angle drill
Old 07-24-18, 07:19 PM
Q
Received 1 Vote on 1 Post
I'm not sure if it's just the drill I have or of I should be using something like a flex bit instead bit I always have to cut 6" + each side of a stud to get it in place. With stuff being 16" apart, that's most of the drywall between that it almost seems better not to have a right angle drill and just cut a 16" section of drywall out.
Any recommended stills or would a flex bit be better with just a small square cut in the middle between studs?
Old 07-24-18, 07:22 PM
XSleeper's Avatar
Received 936 Votes on 854 Posts
Most electricians will have a Milwaukee hole hawg.
Old 07-25-18, 04:48 AM
P
Received 894 Votes on 824 Posts
How big a hole do you need to drill?
Old 07-25-18, 05:11 AM
B
Received 37 Votes on 34 Posts
Drilling in 2x4 studs is always a challenge as you need to stay as close to center as possible. A good patch on a smallish hole is faster and can be just as good or even better than a stud to stud fix. Just IMO.
Bud
Old 07-25-18, 06:50 AM
I
Received 44 Votes on 42 Posts
I find the stubby Irwin Speedbor bits in a regular cordless drill to be perfectly fine for drilling a couple studs.
For a real right angle drill, pretty much all the big brand names make a decent one. Milwaukee used to be the best, but their quality has dropped since they were bought out, and the others have gone up so it's a toss up. Pick which color you like and get that one.
Old 07-25-18, 08:42 AM
Q
Regular cordless drill is at least 8" or more when put in at a right angle. That means cutting out 8-9" of drywall on each side all the way along the wall. There's no easier way with flex drills?
Old 07-25-18, 09:20 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Old 07-25-18, 10:27 AM
P
How large a hole do you need to drill?
Old 07-25-18, 10:35 AM
Q
1/2 or 3/4" usually in 6 studs along a wall in 3 rooms
Old 07-25-18, 12:52 PM
ray2047's Avatar
And remember use stubby spade bits to give more room. Example: https://www.homedepot.com/p/Bosch-Da...5003/203274579
Old 07-25-18, 03:50 PM
pcboss's Avatar
Received 114 Votes on 99 Posts
It is less.work to cut one long slot and.patch instead of multiple holes.
Old 07-25-18, 05:48 PM
P
If you are drilling in a finished wall you really need to cut the sheetrock back to the center of the next joist so the edge of your patch can be screwed to the joist. That leaves a lot of room to work. If you're trying to make a small hole centered over one joist then your patch is going to require more work to secure it's edges.
Old 07-25-18, 07:25 PM
Tolyn Ironhand's Avatar
Received 343 Votes on 296 Posts
While a great drill, the Milwaukee hole hawg is way too much drill for cutting holes for wires/cables. It is more for plumbers that are drilling 2"+ holes.
I use a Milwaukee Magnum right angle drill which is no longer made but this is a very close version. I chuck Bosch Daredevil spade bits of self feeding auger bits to cut the holes I need. 7/8" is my preferred size for 2x's.
https://www.homedepot.com/p/Milwauke...FUp3wQodRPIObQ
