Replacing switch with timer issue.
Received 0 Votes
We have a switch operating an exterior light with power being carried on via the 3 wire from switch to 3 separate plugs on deck. All operates fine until I replace switch with Leviton timer. Tester shows "open neutral" but does NOT show that if simple paddle switch is left in.
We'd need to know what you have for wiring at the switch.
Is it JUST a single three wire cable ?
If yes.... one wire will be hot, white will be neutral and the third wire is switched.
Received 0 Votes
14/2 coming in direct from pony panel in garage...14/3 going to light fixture...14/2 from light fixture to remaining plugs.
When I had simple switch wired up...whites married off together, black in and black out to one terminal on switch and red to the other terminal...everything works fine.
when I replace with a timer trouble arises.
If I'm following you and light is before the receptacles.
Power im black pigtailed to timer line in and black of 3-conductor cable.
Red of 3-conductor cable to timer load out.
All whites together.
Red and white to lights.
Black and whites out to first receptacle.
If your switch was intended for either a single switch situation or a 3-way switch you may have a wire left over unused.
Received 0 Votes
You are correct regarding sequence of fixtures and that is switch - light - receptacle.
Would I treat this is a 3-way situation? I have followed the Leviton instructions as if it's a 3way so perhaps that's my issue...there is NOT a second switch beyond the light.
I will try your suggestion today...thx for your attention.
