Testing a bunch of aaa batteries (most around 1.18-1.21)
Received 0 Votes
You need to use a battery checker that puts a load on it. Voltage will drip under load. How much it drops determines if it is good. To do that you use a battery tester or multimeter with a battery test function. Example: https://www.walmart.com/ip/New-Universal-Battery-Tester-Load-Checker-AA-AAA-9V-C-D-Power-Portable-Load-New/50566860?wmlspartner=wlpa&selectedSellerId=709&adid=22222222227038170306&wl0=&wl1=g&wl2=c&wl3=85318320650&wl4=pla-193241087570&wl5=9027667&wl6=&wl7=&wl8=&wl9=pla&wl10=112343202&wl11=online&wl12=50566860&wl13=&veh=sem
I doubt any of the batteries are good given how low the no load values are.
1.2V is a fully charged voltage for a rechargeable battery, but not for an alkaline battery.
At that voltage without load the batteries are probably 1/3 to 1/2 drained. It will still work on low current devices, but definitely not a fresh battery. You will get 1.5V or slightly higher voltage with a fresh battery. Even when you see correct voltage, that doesn't mean it is good unless you put it on load. That is where battery tester is useful.
Received 0 Votes
I've got one of those cheaper testers...and I don't think it's worth the plastic it's made of. Gardner brand, so not a junk name, but it constantly tells me a battery is plenty good for use (needle just barely below a fresh cell) and yet it won't work in a device. Check with a meter and it's 1.28V or 1.37V or some such.
The little strips that glow yellow or green that come with some batteries are a better test than the testers with a needle...IMO of course. At least they are free.
I toss any alkaline batteries below 1.45 or so...they just aren't going to last.
My biggest objection to batteries is when they leak a $2 battery can destroy a several hundred dollar machine. Even if it were just a flashlight, what leaks can get all over other things. When in doubt, throw it out. (not the equipment just the questionable battery).
Bud
Bud
