Wiring switch
Old 08-01-18, 07:15 PM
A
Wiring switch
Trying to replace a switch, noticed wires from two separate outlets going to switch. Now im looking at three groups of wires (two outlets and one to the celing light fixture) can this be wired to a single pole switch? If so how
Old 08-01-18, 07:19 PM
pcboss's Avatar
Received 103 Votes on 89 Posts
Of you are replacing a switch with the same type it will be wired the same, unless you have more than one wire under a screw head.
Old 08-01-18, 07:29 PM
A
I am updating so its from 1980’s style switch where the wires are slid into the switch not looped around the screw. Not sure if both blacks from the two outlets go under bottom screw and then black from light goes to top screw or if i should harness both blacks tgether with a third piece of black and run just one black to the bottom screw, and also if all three whites just go together like a single outlet to switch goes
Old 08-01-18, 08:05 PM
pcboss's Avatar
In that case you would pigtail the two with a short length of wire and place it under the screw.
Old 08-01-18, 09:19 PM
A
That was my train of thought thsnks
Old 08-02-18, 07:32 AM
A
Capped all three whites together capped and pigtailed the two blacks from outlets together. Getting constant power to the light wether switch is on or off?!
Old 08-02-18, 08:19 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Sounds like you pigtailed a hot to a wire for the lights. Use a meter or test light to determine which blacks are hots.
Old 08-02-18, 09:12 AM
A
Yes that was it. All set and works thanks guys!!
Old 08-02-18, 09:41 AM
ray2047's Avatar
Good job. Thanks for letting us know the outcome.
