Is it ok to tap from light switch for new recepticle?
Old 08-03-18, 07:35 AM
K
I am going to install an additional outlet in our walkin closet so I can put a dehumidifier in there. In the past I have always tapped off of an existing receptacle to get the power for new outlet. However this time I don't have an exsisting outlet on a common wall except for the washing machine.
There is a light switch on a common wall for the kitchen lights. Just wondering if it would be ok to tap into that using the hot wire and neutral?
This would be the easiest by far if it is not a problem.
Thanks
Old 08-03-18, 07:41 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Many older switches do not contain a neutral. If you have one white and one black wire on the switch and no other wires you don't have a neutral. No neutral it can't be used.
Old 08-03-18, 08:00 AM
P
Received 125 Votes on 99 Posts
If a neutral does exist then yes, but use the proper size wire for the circuit size and make sure you are not over loading the circuit by putting the dehumidifier on it. Also do not over fill the switch box.
Old 08-03-18, 08:09 AM
K
There is a neutral. Switch has 2 black on it, 1 hot & 1 going to lights. So it sounds like I am ok as long as I use correct wire size and don't overload circuit. Thanks
Old 08-03-18, 02:27 PM
K
Job done. No problems. Thanks for the input.
