Both lights on on Ground fault outlet
I think lightening struck the ground fault outlet my pool pump is plugged into. The green light is on but the red light is flashing and I cannot reset it. I replaced the outlet but the new one is doing the same thing. Green light on, red light flashing. This is without the pump plugged in. I have also reset the breaker multiple times.
Ideas????
Thanks
Wade
Ideas????
Thanks
Wade
Received 273 Upvotes
Have you pressed the test button and then the reset button? Flashing red is usually a first powered up test and turns off when reset. If the red continues to flash and you can not reset means you have a defective GFCI outlet. What brand is it?
Edit: Are there any other GFCI outlets up stream? Check connections up stream.
Sometimes it requires the use of something like the eraser end of a pencil to push the reset button in.
Ok here is what I found and it makes no sense to me. First I tried to reset the outlet but it would not reset.
With the outlet hooked up I get a very dim green light and a dim flickering red light. However when I touch a test light to the black and white poles I get no voltage to light up the test light. I also tried the test light on just the bare wires without the outlet wired in and still nothing.
I verified that the test light was working on another outlet.
Problem with the breaker?????
Lightning went down the wires to a junction box where I had the wires joined together. The wires and connectors were all melted. I cut the fried wires back and reconnected everything and now my outlets work.
Now the question is why has lightning struck this one outlet twice now? I have the copper ground wires hooked up.
Thanks
Wade
Thanks
Wade
