Question about mounting a switch box.
Old 08-16-18, 11:11 AM
Received 1 Vote on 1 Post
I’m installing a new light switch. The wiring is already run, and I am familiar with what wiring connections have to be made.
One aspect of installing the box is new to me.
Due to an unusual situation in the framing, I can mount the metal switch box to the wide face of a “2 x 4”. The switch box has four holes in the back, and I plan to secure it to the framing by putting screws through those holes. Additionally, it seems like the ground screw will extend past the back of the box. My plan is to drill a small hole in the wood to accommodate the end of the screw.
My question: with that type of mounting be to code, and would there be any problem with drilling a small hole in the wood to accommodate the ground screw?
As always, thanks in advance.
Old 08-16-18, 03:29 PM
Tolyn Ironhand's Avatar
Received 370 Votes on 320 Posts
Drilling out the wood for the ground screw is fine as is attaching the box through the back holes. Normally I just run a standard drywall screw through the threaded hole (then remove it) to make room for the ground screw in the wood. You just don't want to mess up the threads of the hole so I use fine threaded screw.
Old 08-16-18, 07:20 PM
Received 1,613 Votes on 1,485 Posts
Unless it's some real hard wood.... you don't even need to drill for the ground screw.
Old 08-17-18, 05:08 AM
B
Received 113 Votes on 99 Posts
Reinstall ground screw from inside to outside instead of outside to inside.
Old 08-17-18, 06:36 AM
Thanks again to all!
(here are the extra characters for length)
Old 08-18-18, 06:40 AM
As a follow up, the switch went in as described, (I did drill the small hole in the wood for the ground screw) and is working fine. Again, thanks for the info/guidance.
