Doorbell wiring
Old 08-18-18, 11:17 AM
R
Doorbell wiring
I'm installing a ‘Ring video doorbell’ I’ve already replaced the transformer to the correct unit. Now I come to the chime unit and I’m being told to loosen the ‘front’ and ‘transformer’ wires. The problem is that my doorbell chime has 4 wires, not 3, and they’re labeled 0,1,2,3 not front, back, transformer. I’ve used my multi-meter and got power when I touch the white and red but also when I touch the white and black. I don’t know much about electrical, nor do I like it. But I’m trying to finish this project instead of calling an electrician.
Old 08-18-18, 02:35 PM
Received 1,618 Votes on 1,490 Posts
Welcome to the forums.
That is an electronic chime which means when you push the button.... the chime starts and keeps going until it finishes. It requires always live power or batteries.
Did just the front operate the chime ?
You can remove all four wires from the unit and use a meter to identify the transformer lines. When doing this test make sure the doorbell button is disconnected.
Old 08-18-18, 06:49 PM
R
It is operational on both the front and the back.
