Wire size
Old 08-20-18, 04:01 PM
Wire size
Hooking up a sub panel to shop will be 100ft from main box. What would be best wire size and will 100 amp breaker be big enough. Small powder coat oven and 60 gallon compressor both run off 220 will be in the shop.
Old 08-20-18, 04:26 PM
Received 224 Votes on 206 Posts
We can't tell you if 100 amps is enough. Look at what you want to power and add up their amperage requirements.
Old 08-20-18, 06:27 PM
Received 23 Votes on 19 Posts
100A requires #1 Al or #3 Cu.
Old 08-20-18, 07:39 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Since many houses are off a 100 amp service, I would be willing to bet that a 100 amp will run everything you need.
Old 08-21-18, 03:47 PM
Thanks guys. Compressor is 20 amps so the 100 should be enough
