Extending Ungrounded Cable
Received 0 Votes
Seperated from: https://www.doityourself.com/forum/e...conductor.html
I have a 1960's era room which was added on to a 1950's era house. Inside there is a 1 gang metal receptacle which is powered via a 12/3 Romex which has a white, black, and red wire. There is no ground wire but the red is attached to the ground screw. They used to sell 3 wire Romex without a dedicated grounding wire and it appears that they might have simply used the red wire as a ground. I want to connect to this a GFCI receptical on the exterior side of the wall. Please advise.
To answer your question directly.....you can measure from black to red and you should measure 120vAC.
