Ground cable taped?
Old 09-26-18, 03:42 AM
Ground cable taped?
This appears to be the ground cable from the panel. It's just twisted and tried. Is that ok?
Old 09-26-18, 05:47 AM
Received 9 Votes on 9 Posts
Just twisting and/or taping two wires together is not sufficient to make a connection. A wire nut or crimp or screw terminal strip is needed.
Ground wire splices and grounded parts do not need tape or other material as insulation. If there is a soldered joint under the black tape that would also be okay in which case the tape is not really needed.
Old 09-26-18, 06:57 AM
Received 3 Votes on 3 Posts
Splicing of main ground wire from ground rod to service panel is not allowed.
Old 09-26-18, 08:29 AM
So the entire length of ground wire from 3rd floor to ground needs to be redone?
Old 09-26-18, 10:45 AM
From the panel to where????????????????
Old 09-26-18, 12:13 PM
Goes through the floors down to the crawl space. This splice is right outside the panel...
