need 0-10v dimmer for 2' x 4' LED
Old 10-03-18, 04:38 PM
I need a 0-10v dimmer for a
Metalux 47-Watt 2 ft. x 4 ft. White Integrated LED Flat Panel (from Homedepot)
that I just put in and am unsure which one to buy . . and the Lutron website says their dimmers are not compatible with this lamp.
Can someone pleas help me with this?
Old 10-03-18, 04:46 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
In addition to the switchleg and neutral wires 0-10v dimmers require 2 "extra" wires to be run to the LED driver for the dimming control. Any 0-10v dimmer should work with that fixture as the dimming is done by the driver, not by the dimmer. Fun fact: You can dim the lights fully down by touching the gray and purple wires together off the driver. I found that out by accident.
Here is an Example: https://www.homedepot.com/p/Lutron-D...FUQegQodWkIGLw
Old 10-03-18, 06:51 PM
Received 510 Votes on 480 Posts
Lutron offers several choices. Tolyn illustrated one. They are somewhat pricey as dimmers go.
Amazon lists several. I've used the enerlite dimmers before. Here's a generic one.
0-10v dimmer
Old 10-08-18, 07:04 AM
Thank you guys for replies. I ordered a Lutron DVSTV-453P, and my brother is coming over today to wire it.
Thanks for responding so quickly.
