Grounding a switch
Old 10-05-18, 09:30 PM
Received 1 Vote on 1 Post
Grounding a switch
I'm replacing an old dimmer switch which only had two wires - no ground. There are no grounds in the box at all. It looks like the cable going into the box is armoured cable from what I can see.
The new dimmer switches all have the green ground wire. Can I attach a green grounding screw to the metal gang box and attach the green wires of the dimmer switches to it?
Old 10-05-18, 09:43 PM
pcboss's Avatar
Received 40 Votes on 35 Posts
The cable may.not have a grounding means even though it is metallic. It would need a thin bond strip to be a ground.
Old 10-05-18, 10:20 PM
Received 514 Votes on 484 Posts
I would just cap off the green wire and install the device. If the box is grounded.... so will the device be.
Old 10-06-18, 06:49 AM
The cables going into the box are hard to visualize. It's an older 7-gang metal box. Is there a downside of having attached a green screw to the metal box and attaching the green wires there vs capping them off?
Old 10-06-18, 07:41 AM
No downside. You can connect the green wire to a box screw.
