broken hot wire??
Old 10-07-18, 07:47 AM
broken hot wire??
The current was interrupted for only part of a line. I was able to isolate the wire by doing an ohm test. I found no resistance with the hot wire but resistance with the white ground. I am assuming the hot wire broke?? Should this have tripped the breaker? Could there be another cause for this?
Thanks
Alan
Old 10-07-18, 09:16 AM
Received 42 Votes on 40 Posts
ou could have had an overload that tripped the breaker but in the short time before the breaker tripped, one of the connections say between a wire and a receptacle overheated and became loose so as to give you a lot of resistance.
A reminder: Turn off power before measuring resistance or continuity.
Old 10-07-18, 11:23 AM
Received 45 Votes on 39 Posts
The breaker will no trip If the line (hot) wire broke or came loose from a termination. Inspect at the last working and first not working termination points for a loose wire. If none, verify the the cable's hot wire between the 2 points has no resistance and replace.
