Blanks for light switch covers
Old 10-15-18, 09:53 AM
Does anyone know if they make little blanks for a wall plate to cover up a spot where a toggle switch would normally go? I have a 3-gang toggle switch box with two light switches in it (one of the light switches has been removed because it no longer controls anything). Right now, I just have a piece of white electrical tape covering the hole where a toggle switch would normally be. See attached picture for what I'm trying to achieve. The top of the picture is what I have, the bottom of the picture is what I want to achieve. I don't want to put a dummy light switch in there just to cover the hole. I'd rather blank it if a blank exists.
Thanks all.
Old 10-15-18, 10:03 AM
Received 27 Votes on 22 Posts
You need to buy a new switch plate called a (3 Gang 1 Blank switch plate)
Old 10-15-18, 10:13 AM
Never mind, all. My wife located this one. Three-Gang-Plate-Two-Switches
Thanks!
Old 10-15-18, 02:17 PM
Do you have a Lowes or HD nearby?
Old 10-15-18, 04:44 PM
CasualJoe's Avatar
Received 39 Votes on 31 Posts
The special plate is fine, but if you want to do it less expensively and quickly just buy a switch blank. I believe most Home Depot and Lowes stores stock them. This one is a Legrand, but all manufacturers make them.
https://www.lowes.com/pd/Legrand-1-G...nsert/50179255
