Fishing electrical wire through hole in stud
Old 10-21-18, 10:04 AM
K
I'm adding a new base cabinet in my kitchen. The electrical outlet is a few inches too far to the left and would be covered up by the cabinet. I just need to relocate it to the other side of the stud. Is it kosher to just drill a hole in that stud a few inches higher, since we'd be losing a few inches slack in the cord, then reposition everything there?
Old 10-21-18, 10:11 AM
Received 1,531 Votes on 1,414 Posts
Welcome to the forums.
Yes.... you can raise a wall receptacle up to pick up slack in the cable.
Old 10-21-18, 10:13 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes, receptacles have no particular height requirement.
P.S. That isn't a cord. It is a cable.
Old 10-21-18, 10:53 AM
K
Thanks so much for the quick reply. So there isn't anything I need to do to protect the cable, like inserting a sleeve for it to go through? I'm imagining some scenario where being fished horizontally through a hole in the wood could wear on the cable over time, say if the building was settling. Are there conventions about how much slack to leave to offset that possibility?
Old 10-21-18, 11:16 AM
ray2047's Avatar
Sleaves are not needed for wood studs. No slack os generally requited but you need 6-8" of wire in the box.
