Half hot made all outlets "switch controlled"
Old 10-24-18, 04:34 PM
All of the outlets in a bedroom were always hot. We finally decided to figure out what the "extra" switch did. We realized that one of the outlets was wired to be half hot. I broke the tab between the hot wires and wala! The outlet was controlled by the switch! We plugged and light in and we were excited to finally have light when entering the room.
Then, when i turned the switch off and looked around the room i realized that all of the outlets in the room now turn on and off based o the light switch. Ive been researching it and it looks like all the outlets are daisy chained together. The outlet has 2 hot wires, 2 neutral wires, and a ground wire.
I have tried rearranging the placement of the wires and alternating which goes on top v bottom.... but nothing seems to allow the one outlet to remain half hot and the others to stay on.
Any advice on what we can do?
Old 10-24-18, 04:45 PM
Received 4,140 Upvotes on 3,718 Posts
Welcome to the forums.
There are many ways that can be wired. You broke a link at one receptacle. You don't know if that was the switch loop location.
The easiest way I know of handling this is for you to either take and post a picture of the wiring at each receptacle box or explain what you see at each box.
How-to-insert-pictures
Old 10-24-18, 04:48 PM
ray2047's Avatar
Using a multimeter determine which wire is always hot regardless of the switch but if only two blacks you may not have the wires you need.
Old 11-03-18, 08:54 AM
Pictures
I cant find the "go advance" button anywhere so I can attach the pictures
Old 11-03-18, 09:03 AM
pugsl's Avatar
Received 78 Upvotes on 71 Posts
The go advance is all the way on the bottom. It is one of the yellow ones
Old 11-03-18, 09:31 AM
ray2047's Avatar
You need to use a computer not a phone if you don't see it.
Old 11-03-18, 10:10 AM
Received 529 Upvotes on 433 Posts
Tell us about all the wires in this receptacle.
It is possible the problem is in a different receptacle.
