Reload this Page >
15A Breaker cannot handle clothes iron or electric kettle?
Old 10-26-18, 07:02 PM
Hi
The 2 small bedrooms in my 4 year old house share one 15A breaker in the panel
The master bedroom has its own 15A breaker
When I plug in a 1300W electric kettle or a 1000W steam iron into any of the outlets in the 2 small bedrooms, it trips the 15A breaker,
Funny thing is, the master bedroom also has a 15A breaker but there is no issue.
The 2 small bedrooms do not use much electricity. One of the rooms is converted into an office and I run 2 computers, a modem and a router. That is all.
Do you think it is a wiring issue? Is there any way I can get it checked or perhaps increase the Breaker from 15A to 20A?
I think the formula is P=VxA (or A=P/V). so a 1300W kettle would be 1300/120 = 10.83 Amps
I cannot imagine the 2 computers, modem and router requiring too much current. Let us say these items are 300W total = 300/120 = 2.5 Amps.
So we are still under 15A but a steam iron or a kettle (NOT used together) always blow the fuse....
Old 10-26-18, 07:20 PM
Received 1,322 Votes on 1,222 Posts
Wow....a four year old house and two bedrooms on one circuit. I make it a point to put every room on it's own circuit.
Anyway...... a 15A circuit is capable of handling a maximum of 1800 watts. That doesn't mean the breaker won't trip before that. Circuit breakers are thermal magnetic so a heavy load will cause it to trip thermally with time.
You may have a defective breaker or..... is that an AFCI breaker.... has a pushbutton on the breaker ?
That may trip with inductive loads switched on.
You cannot increase breaker size on a wire arbitrarily. The breaker is sized to the cable size that has been run.
Old 10-26-18, 08:09 PM
Hi Pete
Yes, cookie cutter townhouse complex. Builders have cut every possible corner.
And yes, the breaker is AFCI. There are only 2 AFCI breakers in the entire panel - the master bed 15A and the other 15A shared by the other 2 rooms. All the rest are regular breakers. Any reason why they did that?
Old 10-26-18, 08:19 PM
Received 97 Votes on 85 Posts
Bedrooms are required to have AFCI protection while wet locations must have GFCI protection according to code.
Old 10-26-18, 09:43 PM
In the past/current codes....... AFCI was only required in the bedrooms. Now..... with the new code...... almost every circuit will need to be GFI or AFCI protected.
Old 10-27-18, 09:50 AM
H
Received 136 Votes on 118 Posts
It's easy to accumulate 400-600 watts of background draw fairly quickly.
Router and Modem are probably taking up around 50 watts each.
Computers have monitors? Average 22" LCD monitor, figure 50 watts each.
~200 watts, just from peripherals.
Two newish computers with average video cards, probably 400-watt + power supplies in each,
~200-400 watts for 2 computers on (e.g. not in sleep or hibernate)
Printer?
Phone charger?
Lights?
Old 10-27-18, 09:54 AM
Received 83 Votes on 78 Posts
I'd first check to see if they back stabbed the outlets.
If so change it so there under the screws instead.
All it takes is one loose connection to trip an Arc fault.
Old 10-27-18, 02:53 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
I think you know already and answered your own question before asking it.
Surely you have heard of the term, "Low Bid". What you got was a job completed as cheaply as possible. It seems some contractor acquire a reputation for doing that kind of work.
