Buying Inverter Generator - Cable to Transfer switch
Two hurricanes this year in this area and my old generator is on shaky ground. I am preparing to buy a Predator (Harbor Freight) 3500 watt inverter/generator.
My house is professionally wired with a transfer switch. The new generator has a different outlet configuration than the old one. With 3 "slots," one with an end going inward. The old generator had 4 slots. So I need a new AC120 cord to connect to the box outside the house. (Briggs and Stratton/Cutler-Hammer)
So what kind of cord do I need and where do I go to get it? How is that for an easy question? Just thinking it's probably a standard.
Most, including one you are considering, only has 120V output.
If you have any 240V appliances that you have to run on the generator, then you will have to get regular generator or spend a fortune on 120/240V inverter generator.
If you only need 120V, then you can run a jumper wire between 2 hot wires, thus feeding both poles with 120V.
I think the best way to do this is by making an adapter. Get L14-30 inline outlet, L5-30 plug and 1ft of 10/2 SJOOW cable. Connect hot wire from L5-30 to both hot of L14-30.
Then you can just plug your existing generator cord to this adapter.
If you choose to, you can just jut off plug of your generator cord and do the same.
https://www.youtube.com/watch?v=_8gU1X_H3nM
Just found they sell of this adapter and cables ready made as well.
https://www.amazon.com/Parkworld-884.../dp/B01MDJYFDI
Thank you for the great response. That last line was the one that made my day
I am not much for 110 wiring and I was thinking it was getting over my head.
Thanks a bunch. This is a great forum.
FYI. Harbor Freight will have that generator for $679.99 on black Friday.
If you can wait, buy it on black Friday.
https://www.bfads.net/stores/harbor-.../page-3#viewer
Just don't forget that 240V appliances will not work even with an adapter.
Not needing to run 240V. I am house-wired for lights, a heater fan for our propane heat, refrigerator, a microwave. If the end times come we'll have to wash clothes by hand
