Trouble shooting/repair outdoor outlet
Old 10-30-18, 01:44 PM
I have and outdoor outlet that when I test, both sockets show as live with power to them
Yet when I plug in cord, tools only one will supply power?
All wires seem to be connect properly to the back of the outlet.
Any ideas as to the cause?
Old 10-30-18, 01:48 PM
Receptacles only need hot and neutral to work. There is a bridge on both sides where you can break it off if you want to switch one half of the receptacle. Be sure that bridge is in on both sides.
For a more reliable connection.... the screw terminals should be used.
When you check for power..... use a meter..... not a non contact test pen.
Old 10-31-18, 10:01 AM
thanks.........appreciate your taking the time to reply.
Old 10-31-18, 11:44 AM
How are you testing that both outlets show hot? If using a non-contact type tester they are notorious for giving false positives.
