Electric service head caulking
Old 10-30-18, 06:32 PM
Danny258's Avatar
HI I am getting water in to my panel through my service head ground wire running through the wire into the meter box dripping down into my box I was told to caulk the service head my problem is will I get shocked up at the head while caulking it to seal the ground wire going in .
Old 10-30-18, 06:44 PM
L
Received 48 Votes on 44 Posts
You should not get shocked as long as insulation on the wire is good.
You should not need to caulk weather head if it was properly installed and is not damaged.
Does your service drop have drip loop?
Wires should be looped lower than weather head.
Old 10-30-18, 06:52 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If there is a drip loop you shouldn't have a leak.
Img source: hsdi.us/library/electrical/
Old 10-30-18, 06:55 PM
Danny258's Avatar
No it is on an angle not strait up on a 90 degree angle mounted to the house its the old metal square head but it is a 200 amp service line coming in the house
Old 10-30-18, 07:45 PM
L
As long as head of the weather head is pointed toward top and the service drop has drip loop, water should not get in.
If the joint between conduit and weather head has failed, it is possible for some water to get in. In that case, it may be caulked, but this may be just a temporary solution.
If you don't have drip loop, caulking may stop or slow water entering the conduit for a while, but will eventually fail.
The power company is responsible for the service drop and they should come out and extend or replace the wire to have drip loop.
If you have service entrance cable (a thick gray cable) instead of conduit, check sheeting of the cable. If sheeting has failed, water can get in.
Old 10-30-18, 08:02 PM
ray2047's Avatar
Please post a picture. How to add images.
